Just ordered all the parts for my smartrap.
I ordered:
x4 nema 17 steppers (bought a used set of 5 because I intend to try dual extrusion.)
x1 ramps 1.4 w/ arduino shield
X1 jhead lite v2.1 (.4mm)
X10 end stops (ordered from http://dx.com and have to be wired up/ soldered up)
6mm linear rod for x and y axis’
8mm linear rod for z axis
X12 lm8uu bearings (although I am going to try to print bushings)
x10 lm6uu bearings (also trying to print bushings
X2 push fittings for ptfe tubing
2meters of 4mm od 2mm id ptfe tubing (for Bowden system)
If anyone wants the links to any parts please let me know!
What about the printed parts?
Dont forget to buy some fan, or your Jhead arm can melt, or just bend :slight_smile:
@Enrico_Colautti I have access to another 3d printer so I printed them myself. If you want a kid makercoast sells them for $25 on eBay.
@Kamil_D I’ve also got a 40mm fan lying around that I’m gonna use. I don’t want to melt any hotend mounts!
So hook it up to the power, so it will run all the time. Then if you want you can print some mount from thingiverse for second nozzle fan :slight_smile:
I was having parts from makercoast, overall printed nice, but abs and around 25 infill (if i remember right) wasn’t enough and they were cracking and breaking :confused: Only lot of trouble, at least for me.
They also offer pla which is what mine are printed out of.
Are you saying splice the fan in where I get power from my power supply?
So its good. When I was ordering they were having only Abs parts.
Yes, wire it to the connector where you crimp your atx cables to ramps. I can take a photo for you, but give me 1 hour to get back home from university. You can also change in Marlin to use two fans, but its easier, and the fan is running after every power up of the printer.
I just bought an I3 printer, but still waiting for the delivery. BTW, mieszkasz może w Warszawie?
Nie, do Warszawy mam daleko. Mieszkam w Zawierciu na Śląsku. Gdzie kupiels i3? :slight_smile:
W Chinach.
http://www.aliexpress.com/item/2014-Newest-Aurora-Reprap-Prusa-i3-3D-Printer-Machine-Open-Source-3D-Print-Easy-Installation-DIY/1883624249.html
Sprzedawca ma dobre oceny i mam nadzieję, że będzie OK. Już tam kupiłem elektronikę do innej drukarki i wszystko było w porządku.
