Just pushed new code to master enabling 4-way parallel output on the ESP8266.
It seems to be working pretty solidly, though as with other parallel outputs, you have to be careful about cross talk between your data lines since all of them are being written to at the same time.
(Why only 4 way? Because while the ESP8266, in theory, has 17 GPIOs, 6 of them are permanently unavailable to us, and they’re right in the middle of the pack. This leaves the block of 4 pins at raw GPIO’s 12,13,14 and 15 and/or the GPIO’s at the low block of pins 0-5. I elected to only support parallel on the high block for now, since in the 0-5 block, pin 1 and 3 are used by the USART, so once again, no contiguous pins on the port to use for parallel output).
Enjoy!
