Just read a little bit on it, but seems interesting…though not sure on implementation to run with FastLED:
http://www.ti.com/product/lp5036?HQS=app-psil-led-lp50-retext-pf-FacebookAdroll-wwe&DCM=yes&dclid=CPGr4aX65d8CFQy2swod_CwCcg
i2c will quickly make you long for the relatively speedy (especially once you factor in parallel outputs) ws2812
– also, w/12-bit output, it’s a 50% increase on the amount of data to write for a frame. (I probably won’t start implementing support for 12/16 bit chipsets until I finish the RGBW/RGB16 work)
