Just switched the Smoothie wiki from being hosted at Wikidot, to being self-hosted using DokuWiki.
The URL doesn’t change : http://smoothieware.org/ and in theory, not much else should change.
It was a lot of work and translation between wiki formats. If you find something that is broken, don’t hesitate to tell me, or to edit it yourself.
One good thing that comes from this, is the wiki no longer requires creating an account to edit, you can just edit it instantly, right now.
Found a broken url to a image http://smoothieware.org/delta under “Delta kinematics basic”.
And “The two most important parameters are as follow :” and “to be 120° apart” a bit below that
Oh, the blog is also a bit odd
http://smoothieware.org/blue-box-guide
lost it’s imges
@StephaneBUISSON Noted, thanks. Seems a lot of pages have, will go over all of them /o\
broken link to delta.png fixed
@Glenn_Beer Thanks ! Don’t hesitate to do some more of that
