Just thought I would ask since I can't find the specs on them.  For
Just thought I would ask since I can’t find the specs on them. For the Rods in the Diffs for the gears, What size are they?? length and diameter. Also for the central drive shafts going from central diff to front and read diff, and the drive shafts for the diffs to the wheels. I had read somewhere on here talking about using welding rod for the drive shafts but i cant seem to find it.
Some sizes I used for the rods:
3x Differential Rod 3mm length ~18.0mm
4x Wishbone Outer Rod 2mm length ~32.0mm
4x Wishbone Inner Rod 3mm length ~58.0mm
I used the following conrad items 237051 and 237213.
I’ll look into that, hopefully its not too bad for shipping. I’ll check out McMaster also. Thanks again
Hi Lawrence, i used spokes from a wheel of an old bike. Works perfectly till now.
Ok thanks, ordered some 2mm and 3mm smooth rod from mcmaster along with the m3x50mm screws for the shocks . Thanks for your help
