K40 whisperer - problems at vector cut only - red line?
Hello,
joined here to post this question, hope it is not against the rules.
Raster engrave and Vector engrave works as it should. But when i hit button Vector cut, laser head wants to go out of range(in upper left corner - if home is upper right corner) and i have to shut laser off.
Did anyone experience something similar or have any ideas what could it be?
Thank you.
More than likely you have a red (vector cut) line off of the page in the SVG file.
You can try opening the file in Inkscape and zooming out to find the extra feature. Then you can remove the extra feature.
Thank you very much, that was the case.
