K40 Whisperer Request
This issue is probably caused because I am old, but :
I keep forgetting “Rotarty” is ticked on. Then I start a job and it is ruined.
Would it be possible to indicate somewhere on the main screen that its enabled? Maybe change the text of the “Raster” button to “Raster Rotary”?
I will give it some thought.
On my version (v0.54) ‘Use Rotary Settings’ is unticked by default.
My laser is running on a PI, which I never turn off (along with the water pump).
So with the K40 off, I setup the rotary device, or remove it, then turn on the K40 and log into the PI.
At this point, the rotary setting is what ever it was last.
I know this is local to my setup, but keeping a setting that affects the machine functionality visible seems like a good idea.
