Kessel making short stops while extruding:
Kessel making short stops while extruding: http://youtu.be/-Vr1z16w4fY please help me about
thank for your reply, but unfortunately I have to say it happens everytime, every software I use : I tried printing manually from Sd card, and by Pronterface connected on USB, having the same result< and the defect is present while moving from homing to the bed (ex. G1 Z10), I don=t know what and where to find…
Are you reaching your segs/sec limits in Marlin? If you have a larger delta, 1/32 microstepping and are running relatively high print speeds like 80mm/sec (and especially if you have a .9 deg stepper too) you may be maxing out the planner. There’s a setting delta segs/sec which is default at 200, you might try setting this lower:
#define DELTA_SEGMENTS_PER_SECOND 160
Each of the controlled steppers contributes to this max, so you could also lower the microsteps for e.g. your extruder and squeak out a little more performance - otherwise you might use repetier firmware which is a bit more efficient, or just move to 32 bit like Smoothie firmware on Smoothie board or Azteeg X5.
Are you using RepRapDiscount Full Graphic Smart Controller? Known problem with deltas and ramps.
Yes, I have that display, after disabling it no more problems, now the question is : is there a way to keep it working without problem?
This happened to me also, I asked a few times on IRC but never got a solution. I ended up switching the XXL smart controller on my prusa i3 with the delta’s full graphic and now it doesn’t miss a beat. I’m guessing it just takes more processing power to use the full graphic display.
