Kustom kossel maxi Aka Sardaukar update/
First print : promising !
Did your arms need to be so long? You could have made the whole printer a lot smaller with shorter arms.
yes, the build volume diameter is dependent of the arms length.
my goal was to made a silent printer with big print volume. i think i have almost 250 mm diameter by 240 heigth build print.
the arm is not so long for the build volume :, it’s 305 mm center to center.
