Hallo Smoothieboard Freunde. möchte auf meinem 3d Drucker parallel einen Laser betreiben. Kann ich mit zwei SD Karten arbeiten oder muss jedesmal mit firmware.bin und firmware_cnc.bin das Board neu geflasht werden?
Sorry parallel betreiben.
I’m not sure what you mean, would you mind translating?
Hello smoothie board friends. would like to operate a laser in parallel on my 3d printer. Can I work with two SD cards or does the board have to be flashed again with firmware.bin and firmware_cnc.bin?
I would recomment you simply enable the laser module on a 3D printer build, it’s definitely going to be the simplest solution to your issue.
