Problem description
I’m newbe in Laserweb. I worked with Lightburn before. I can’t find any tutorial how to adjust Z axis in Laserweb for my laser. Can anyone explain how it works in LW?
System description
- My machine is a diode laser - TwoTrees T2S
First, you need to activate “MACHINE Z STAGE” in settings / machine. This gives you the Z axis on the DRO and the up/down buttons.
Then touch the surface of your material with the cutter and klick on the down arrow in the Z DRO. There you have “Set Z Axis Zero”.
