@cprezzi Did you try to install the server [1] on a Pi Zero? [1] https://laserweb.yurl.ch/documentation/installation/36-install-raspberry-pi
No, I never tried, but the backend should work correctly.
It’s not recmmended to run the frontend on a raspi. Instead run the frontend on a PC and only connect the backend over network. This is because the frontend needs a lot of ressources and CPU power.
You can use the normal installation for the frontend, or just open the embeded website from the server with a browser. Don’t froget to change the Server adress in the frontend (unter “comm” tab / “server connection”).
Thanks you for your reply.
I’ll try to install just the backend and report back.
