@Ariel_Yahni_UniKpty We cut aluminum plate with an xcarve like hobby CNC machine. We have to go slowly but it works fine. The only problem is that the cuts take a long time for each line of gcode.
There is no timeout on our side for the USB serial connection!
If the connection get’s lost, it’s either forced by OS power save function, or the connection is instable for some reason.
One reason could be the smoothieware dual USB connection (CDC + MSD). Try disabling MSD (access to SD-Card drive).
Another reason could be an instable connection caused by bad/long USB cable, which causes too low voltage on the smoothieboard (if the optional power regulator is missing).
@Quentin_Harley Do you also run the frontend on the Raspi, or just the server? We don’t recommend running the frontend on the Raspi (not enough power/ressources).
Hi @cprezzi I have grbl1.1 on the smoothieboard, so no MSD interference.
Replaced the USB cable already. It is one of those 15cm long stubby cables, so I don’t think it would cause the issues.
The Pi is just the back end. Run the web interface from my PC in Chrome.
Using a separate 5V regulator, so it is not power related either.
Stumped. It works when doing intricate cuts in wood that requires a lot more (but shorter) gcode moves. This is why I suspected some kind of timeout.
Do you only get the disconnect error on the frontend or does the machine also stop moving?
At the moment you press run, the whole gcode is sent to the server on the Raspi (array in memory) and the server streams the gcode line by line to the board.
Do you know it Raspbian has a USB power save timeout?
By the way: It is important to remove M2 from the end gcode for grbl-LPC.
