I have an Azteeg X5 v1.1 and a 8 Watt LCheapo Diode laser with PWM.
I used an oscilloscope and found pin 3.25 configured as open drain will produce a 5 v pwm signal when the scope + is connected to an unused end stop ground terminal and the scope - is connected to pin 3.25. I tested this with the latest firmware and using Pronterface command of @fire 90. I also used @fire 50 and saw the pulse change according. I did not have the laser wired in at all, I just wanted to verify the board could produce the correct signal.
Now when wiring in the laser I land the power wires from the laser on the 12VDC power supply and the connection from the end stop ground to the PWM wire of the laser. Where do I land the pin 3.25 connection? I guess I should say which ground, I tried the 12vdc common but that did not work and I hate just plugging into random pins.
What am I missing.
Thank you
