LEDstimator 1.0 — the iPhone tool for planning Neopixel, Dotstar and other smart LED pixel projects
Available now for free on the iOS App Store, LEDstimator 1.0 is a tool for artists and makers planning Neopixel, Dotstar, WS28xx family and other smart LED pixel projects. Simply select the type of LED pixel module you would like to use and enter the required pixel count. LEDstimator will then show you the maximum current and power draw for that number of LEDs, plus an estimate of run time for a given battery type and capacity.
LEDstimator also has a handy DC voltage drop calculator. Enter the cable length and gauge (in metric or imperial units), required current carrying capacity, and starting voltage and LEDstimator will calculate the final voltage at the end of your power cabling.
Quickly and easily run “what-if” scenarios, trading off pixel density, power supply rating, battery capacity and run time. Avoid costly design mistakes before ordering cabling, power supplies and batteries!
LEDstimator 1.0 is designed for iPhone and requires an iOS device running iOS 8.3 or later.
