lost an extruder direction
hi all… dire need of assistnce…
click extrude, it now reverses the filoment out
click reverse, it still reverses the filoment out.
its been standing for three weeks and had the bearings replaced, everything else is as it was before.
what to do?
thank you…
If you disconnected and re-connected wiring, it might be that the stepper for the extruder isn’t wired the same. There’s a step in the 3d printer setup guide that talks about motor wiring and it might be helpful to double check.
If you’re sure it didn’t change ('cause you didn’t move the wiring) then ignore this.
maybe only 3 of your stepper motor wires are going to the driver, this would cause this problem. maybe re-do your crimping ?
i’ll give it a try thank you Arthur.
ahh, a developement, the motor works correctly else where on the board, and now the exstruder port just loadly clats about a tooth clock wise then a tooth anticlockwise, jigging to and fro…
think the driver or something is papped.
