Love the new “EVERY_N_MILLISECONDS”!
Is it possible to do something like this?:
EVERY_N_MILLISECONDS( a_dynamic_maybe_even_random_variable ) {
something();
Yes! I’ll post example code later tonight if no one else has by then, when I have better internet access.
Short version: use EVERY_N_MILLIS_I – note the “I” on then end. This takes TWO arguments, so you choose a ‘name’ for this timer, and set the initial value. Then you can adjust the period for the timer inside the body:
EVERY_N_MILLIS_I( thistimer, 100 ) { // initial period = 100ms
thistimer.setPeriod( random8( 10, 200) ); // random period 10…200ms
…do whatever…
Check out “CEveryNTimePeriods” in lib8tion.h for more info on what you can do when you have access to the timer object.
Also note that the native name is EVERY_N_MILLIS_I. I just added EVERY_N_MILLISECONDS_I as an alias in the github repository on the 3.1 branch.
Freaking awesome! Thanks again
@Mark_Kriegsman is there also something like EVERY_N_HOURS ? I’d like to use it on an aquarium installation…
Yep! Check lib8tion.h. I think there are millis, seconds, minutes, hours, and days.
Bear in mind that the onboard clock isn’t terribly accurate (off by minutes a day).
Thanks a lot Mark! Hope the fishie’s internal clock is even less accurate
If you want to provide an external time source (other than the on-board clock, which is pretty bad), you can, by doing this:
#define USE_GET_MILLISECOND_TIMER 1
then you can provide a function matching this signature
uint32_t get_millisecond_timer()
… read your real-time-clock, and convert to millis …
return clockmillis;
All the FastLED timer (and beat) functions will then use that as their time source. If I hadn’t hiked a 2,800-foot ascent up a mountain today, I’d post sample code… maybe if I recover, over the weekend…
