Here is what shows up in terminal window after I connect to Arduino via Chilipepper GRBL, it seems to close itself down:
Last login: Sat Apr 15 11:26:32 on console
You have new mail.
Tylers-MacBook-Pro:~ tylercartner$ /Users/tylercartner/Downloads/1\ HARDWARE/Arduino/serial-port-json-server_1.86_darwin_amd64/serial-port-json-server ; exit;
2017/04/15 12:07:53 main.go:89: Version:1.86
2017/04/15 12:07:53 main.go:96: Hostname: Tylers-MacBook-Pro.local
2017/04/15 12:07:53 main.go:102: Garbage collection is on using Standard mode, meaning we just let Golang determine when to garbage collect.
2017/04/15 12:07:53 main.go:115: Starting server and websocket on http://10.0.1.9:8989
2017/04/15 12:07:53 main.go:118: The Serial Port JSON Server is now running.
2017/04/15 12:07:53 main.go:119: If you are using ChiliPeppr, you may go back to it and connect to this server.
2017/04/15 12:07:53 main.go:129: You can enter verbose mode to see all logging by starting with the -v command line switch.
2017/04/15 12:07:54 main.go:144: Your serial ports:
2017/04/15 12:07:54 main.go:151: {/dev/cu.Bluetooth-Incoming-Port cu.Bluetooth-Incoming-Port [] }
2017/04/15 12:07:54 main.go:151: {/dev/cu.usbmodemFA131 cu.usbmodemFA131 [] }
2017/04/15 12:07:54 main.go:151: {/dev/tty.Bluetooth-Incoming-Port tty.Bluetooth-Incoming-Port [] }
2017/04/15 12:07:54 main.go:151: {/dev/tty.usbmodemFA131 tty.usbmodemFA131 [] }
fatal error: unexpected signal during runtime execution
[signal 0xb code=0x1 addr=0x25b59a90672 pc=0x4108520]
goroutine 13 [running]:
runtime.throw(0x45515e0, 0x2a)
/usr/local/go/src/runtime/panic.go:527 +0x90 fp=0xc8205153e8 sp=0xc8205153d0
runtime.sigpanic()
/usr/local/go/src/runtime/sigpanic_unix.go:12 +0x5a fp=0xc820515438 sp=0xc8205153e8
sync.(*Pool).Get(0x46fba20, 0x0, 0x0)
/usr/local/go/src/sync/pool.go:101 +0x40 fp=0xc820515488 sp=0xc820515438
fmt.newPrinter(0x0)
/usr/local/go/src/fmt/print.go:133 +0x27 fp=0xc8205154c8 sp=0xc820515488
fmt.Sprintf(0x44d5310, 0xc, 0xc820515658, 0x1, 0x1, 0x0, 0x0)
/usr/local/go/src/fmt/print.go:202 +0x2b fp=0xc820515518 sp=0xc8205154c8
log.Printf(0x44d5310, 0xc, 0xc820515658, 0x1, 0x1)
/usr/local/go/src/log/log.go:289 +0x49 fp=0xc820515568 sp=0xc820515518
main.(*BufferflowGrbl).OnIncomingData(0xc82040c000, 0xc8203142d0, 0x26)
/Users/alden/Projects/proj82_go/src/serial-port-json-server/bufferflow_grbl.go:114 +0x32c fp=0xc820515910 sp=0xc820515568
main.(*serport).reader(0xc8204a8000)
/Users/alden/Projects/proj82_go/src/serial-port-json-server/serialport.go:142 +0x3ec fp=0xc820515ca0 sp=0xc820515910
main.spHandlerOpen(0xc8200158f5, 0x16, 0x1c200, 0xc820015913, 0x4, 0xc820015900)
/Users/alden/Projects/proj82_go/src/serial-port-json-server/serialport.go:499 +0xc68 fp=0xc820515f60 sp=0xc820515ca0
runtime.goexit()
/usr/local/go/src/runtime/asm_amd64.s:1696 +0x1 fp=0xc820515f68 sp=0xc820515f60
created by main.checkCmd
/Users/alden/Projects/proj82_go/src/serial-port-json-server/hub.go:162 +0x670
goroutine 1 [IO wait]:
net.runtime_pollWait(0x4faa110, 0x72, 0xc82000a160)
/usr/local/go/src/runtime/netpoll.go:157 +0x60
net.(*pollDesc).Wait(0xc8204a86f0, 0x72, 0x0, 0x0)
/usr/local/go/src/net/fd_poll_runtime.go:73 +0x3a
net.(*pollDesc).WaitRead(0xc8204a86f0, 0x0, 0x0)
/usr/local/go/src/net/fd_poll_runtime.go:78 +0x36
net.(*netFD).accept(0xc8204a8690, 0x0, 0x4faa208, 0xc820311ac0)
/usr/local/go/src/net/fd_unix.go:408 +0x27c
net.(*TCPListener).AcceptTCP(0xc8203082c8, 0x40a1be0, 0x0, 0x0)
/usr/local/go/src/net/tcpsock_posix.go:254 +0x4d
net/http.tcpKeepAliveListener.Accept(0xc8203082c8, 0x0, 0x0, 0x0, 0x0)
/usr/local/go/src/net/http/server.go:2135 +0x41
net/http.(*Server).Serve(0xc82030aea0, 0x4faa1d0, 0xc8203082c8, 0x0, 0x0)
/usr/local/go/src/net/http/server.go:1887 +0xb3
net/http.(*Server).ListenAndServe(0xc82030aea0, 0x0, 0x0)
/usr/local/go/src/net/http/server.go:1877 +0x136
net/http.ListenAndServe(0x44c7118, 0x5, 0x0, 0x0, 0x0, 0x0)
/usr/local/go/src/net/http/server.go:1967 +0x8f
main.main()
/Users/alden/Projects/proj82_go/src/serial-port-json-server/main.go:169 +0xd26
goroutine 17 [syscall, locked to thread]:
runtime.goexit()
goroutine 11 [IO wait]:
net.runtime_pollWait(0x4faa050, 0x72, 0xc82000a160)
net.(*pollDesc).Wait(0xc8204a8760, 0x72, 0x0, 0x0)
net.(*pollDesc).WaitRead(0xc8204a8760, 0x0, 0x0)
net.(*netFD).Read(0xc8204a8700, 0xc82009e400, 0x400, 0x400, 0x0, 0x4fa0050, 0xc82000a160)
/usr/local/go/src/net/fd_unix.go:232 +0x23a
net.(*conn).Read(0xc8203082d0, 0xc82009e400, 0x400, 0x400, 0x0, 0x0, 0x0)
/usr/local/go/src/net/net.go:172 +0xe4
bufio.(*Reader).fill(0xc82030af60)
/usr/local/go/src/bufio/bufio.go:97 +0x1e9
bufio.(*Reader).Read(0xc82030af60, 0xc8202f0040, 0x2, 0x8, 0xc82030e000, 0x0, 0x0)
/usr/local/go/src/bufio/bufio.go:207 +0x260
http://github.com/gorilla/websocket.(*Conn).readFull(0xc8202b4000, 0xc8202f0040, 0x2, 0x8, 0x0, 0x0)
/Users/alden/Projects/proj82_go/src/http://github.com/gorilla/websocket/conn.go:546 +0xa9
http://github.com/gorilla/websocket.(*Conn).advanceFrame(0xc8202b4000, 0x0, 0x0, 0x0)
/Users/alden/Projects/proj82_go/src/http://github.com/gorilla/websocket/conn.go:570 +0x159
http://github.com/gorilla/websocket.(*Conn).NextReader(0xc8202b4000, 0xc8202f0030, 0x0, 0x0, 0x0, 0x0)
/Users/alden/Projects/proj82_go/src/http://github.com/gorilla/websocket/conn.go:705 +0x76
http://github.com/gorilla/websocket.(*Conn).ReadMessage(0xc8202b4000, 0xc82000c4e0, 0x0, 0x0, 0x0, 0x0, 0x0)
/Users/alden/Projects/proj82_go/src/http://github.com/gorilla/websocket/conn.go:768 +0x55
main.(*connection).reader(0xc8200f7f00)
/Users/alden/Projects/proj82_go/src/serial-port-json-server/conn.go:21 +0x2b
main.wsHandler(0x4faa3b0, 0xc8202ac0b0, 0xc8202e7260)
/Users/alden/Projects/proj82_go/src/serial-port-json-server/conn.go:55 +0x2fc
net/http.HandlerFunc.ServeHTTP(0x458dda8, 0x4faa3b0, 0xc8202ac0b0, 0xc8202e7260)
/usr/local/go/src/net/http/server.go:1422 +0x3a
net/http.(*ServeMux).ServeHTTP(0xc820014930, 0x4faa3b0, 0xc8202ac0b0, 0xc8202e7260)
/usr/local/go/src/net/http/server.go:1699 +0x17d
net/http.serverHandler.ServeHTTP(0xc82030aea0, 0x4faa3b0, 0xc8202ac0b0, 0xc8202e7260)
/usr/local/go/src/net/http/server.go:1862 +0x19e
net/http.(*conn).serve(0xc8202ac000)
/usr/local/go/src/net/http/server.go:1361 +0xbee
created by net/http.(*Server).Serve
/usr/local/go/src/net/http/server.go:1910 +0x3f6
goroutine 9 [select]:
main.(*hub).run(0x46fbf00)
/Users/alden/Projects/proj82_go/src/serial-port-json-server/hub.go:51 +0x7f7
created by main.main
/Users/alden/Projects/proj82_go/src/serial-port-json-server/main.go:161 +0xc90
goroutine 10 [select]:
main.(*serialhub).run(0x46fbf40)
/Users/alden/Projects/proj82_go/src/serial-port-json-server/serial.go:130 +0xbff
/Users/alden/Projects/proj82_go/src/serial-port-json-server/main.go:163 +0xcb4
goroutine 12 [chan receive]:
main.(*connection).writer(0xc8200f7f00)
/Users/alden/Projects/proj82_go/src/serial-port-json-server/conn.go:32 +0x60
created by main.wsHandler
/Users/alden/Projects/proj82_go/src/serial-port-json-server/conn.go:54 +0x2ee
goroutine 14 [chan send]:
main.(*BufferflowGrbl).SetPaused.func1(0xc82040c000, 0x1)
/Users/alden/Projects/proj82_go/src/serial-port-json-server/bufferflow_grbl.go:425 +0x45
created by main.(*BufferflowGrbl).SetPaused
/Users/alden/Projects/proj82_go/src/serial-port-json-server/bufferflow_grbl.go:429 +0x8f
goroutine 15 [select]:
main.(*BufferflowGrbl).rptQueryLoop.func1(0xc8200aa1c0, 0xc8204a8000, 0xc82040c000)
/Users/alden/Projects/proj82_go/src/serial-port-json-server/bufferflow_grbl.go:378 +0x64e
created by main.(*BufferflowGrbl).rptQueryLoop
/Users/alden/Projects/proj82_go/src/serial-port-json-server/bufferflow_grbl.go:397 +0xc2
goroutine 16 [chan receive]:
main.(*serport).writerBuffered(0xc8204a8000)
/Users/alden/Projects/proj82_go/src/serial-port-json-server/serialport.go:228 +0xd2
created by main.spHandlerOpen
/Users/alden/Projects/proj82_go/src/serial-port-json-server/serialport.go:496 +0xc38
goroutine 50 [chan receive]:
main.(*serport).writerNoBuf(0xc8204a8000)
/Users/alden/Projects/proj82_go/src/serial-port-json-server/serialport.go:263 +0xae
/Users/alden/Projects/proj82_go/src/serial-port-json-server/serialport.go:498 +0xc5a
goroutine 51 [chan send]:
main.(*BufferflowGrbl).SetPaused.func1(0xc82040c000, 0x2)
logout
Saving session…
…copying shared history…
…saving history…truncating history files…
…completed.
[Process completed]
