Machine is not engraving, test button does not work on panel but does work from test button on psu. Bad psu? I’ve taken it out no obvious damage to any components.
Disconnect then check across the terminals of the test switch on the panel with an ohm meter while pushed. Should be zero ohms.
While connected short the terminals on the test switch. Should fire…
