Made a cheeky quadcopter frame with my shapeoko 2, if you look at the video you can see lots of swarf and rough edges, anyway i can make it cut better?
blog: http://skyhighrc.wordpress.com
http://www.youtube.com/watch?v=UGW7mtH_xKQ
A dull end mill can cause the rough edges. Also, the best investment is a downcut end mill. You’ll have to be very mindful of clearing out the chips since they will be thrown into the cuts but they leave a very smooth finish on the top surface. Great video BTW.
thanks! yeh that might be a good plan, I’ll have to rig up a dust extraction thing for that it htink
Impressive video; even more impressive is that that appears to be a stock SO2. Do you have it in a “noise reduction” box?
Nice looks like the old flite test electro hub
@Matt_Kasdorf yeh I am planning on getting a quiet cut spindle as soon as possible, yeh I build an enclosure with some polycarb and scrap woood. works very well for noise reduction!
@SonicStrikeFPV yep
I based it on the old anycopter that was superseded by the electrohub, I am going to try and do an electrohub with some fiberglass pcb. Dust extraction will be an issue though…
