Main frame done. Prototype XY done, but I need to cut down the rods so it fits in the frame.
Now I am building the prototype z stage, substituting lead screws with 8mm x 1.0 rod. It’s nice to see things coming together. And more importantly what should be redesigned.
@Eric_Moy I am going to see how the h-bot performs first. If there are issues I already have the CoreXY varient designed. The change from H-bot to CoreXY would be pretty easy.
@Wayne_Friedt just for fun I stood in it (with a piece of plywood on top). This thing’s a beast. I always design for overkill. Inherited that from my Dad.
Do you mean on Z? For Y I have two parallel rods (one per side) under the plywood. For X I have two rods stacked vertically and connected at the ends riding on the Y rods. Z travel is just the bed up and down. It will ride on the two pieces of open builds vslot.
@Eclsnowman , you’ve inspired me to work on my design again. I like the idea of the vertical stacked rods for x. I’m doing core xy, and thinking instead of stacking and crossing the two belts, have one above the y rods and one below. Not sure how it’ll work out. Just finished modeling and constraining the rods and bearings in solid works. Will upload pics once I get the pulleys in
