Mathias Did you get a chance to work on the ramps 1.4 and Repetier
Mathias
Did you get a chance to work on the ramps 1.4 and Repetier configuration? Does anybody else have Repeiter / rampa1.4 working? I’m still unable to print.
sorry, I wasn’t able to fix the problem yet. I hope I will know more tomorrow evening.
hm, I might need more debug data. Could you please enable debug logging, then try to connect and when it fails send me the console output (long press on console -> send email). Thanks !
@Mathias_Dietz
Did you get my debug log…
thanks Danny
@Danny_Dd yes, sorry I was about to answer but got distracted.
Even so GCodePrintr is not sending line numbers to the printer, repetier fw seem to expect a line number when it requests a resend. Otherwise it hangs in a resend loop (this is what your output shows).
I have just implemented a resend handler and will publish a new beta version soon.
I still don’t know why repetier has requested a resend, it can happen when you have a bad serial line quality or when a wrong gcode is send. But lets try the new beta version first and see how it goes.
1.60 Beta is available. Please opt-in for the beta and try the new version. http://gcodesim.dietzm.de/FAQ.html#beta
@Mathias_Dietz
having trouble uploading the beta version. I opted in but probably Google+ account is screwing me around. Updates should be automatic on my android after I opt in correct?
@Danny_Dd yes, update should happen automatically. Make sure you opt-in with same userid as used for Google play
@Mathias_Dietz Ok got 1.60 ,still not working .Sent report .thanks Danny
