Milled clamps
Clamps
Nice and clean. Is that MDF or plywood?
FYI: The nuts / clamps look like they may be backwards? With the nuts on the top, they could slip out due to the upward force of the bolt when clamped.
Just be sure to use the clamps with the nuts facing bottom.
Yes, you are correct!, the actual position is only to show in the picture. Thank you.
The file is: https://www.dropbox.com/s/omkc64k6l6idpmj/Clamp_2.dxf?dl=0
