More design issues/frustrations:
1/ The two lower adjusting screws for the y-axis steppers are inaccessible when the gantry is mounted on the rails. How exactly are we meant to take up the slack in the belt when you can’t get at the screws while the belt is in place. The only way to adjust the stepper is while the gantry is off the rails, at which time you don’t have the belt fitted to the sprocket, so you have no idea how much to adjust. It looks like the only opportunity for adjustment is by tensioning the belt at the anchor point - completely the wrong way to do it.
2/ Unless you buy stepper motors threaded for M5 bolts, you need to fit a nut to your mounting bolt. The best way to do this is to mount the screw and the stand-off to the stepper, push it through the holes in the gantry plate and then affix a nut on the wheel-side of the gantry plate - except you can’t. There is no clearance. SO, you have to push the low-profile screw through the plate from the wheel-side, then try and fit a spanner or socket in the tiny space between the stepper and the nut - I tried 4 different types of stepper - the clearance is all similar - negligible. That’s because they weren’t designed to be used that way - the screw is meant to come from the back side of the stepper, through to the face. That’s how they have ALL been designed, except for the ones that have been tapped for an M5 screw - which are few. I can’t understand why the designer didn’t encounter this problem in assembly himself? I’ve had my gantry apart a few times now - all because of things like this - inaccessible adjustment points.
3/ Even if you did buy threaded steppers, you can’t access the lower stepper mount screws to loosen or tighten them with the gantry in place. So why are they even adjustable? You can’t adjust them - unless you kept the bottom two finger-tight and only tighten the top two? You will have to thread-lock them and hope they don’t work loose over time.
Again, how did that pass any sort of assembly test?
If you are making one of these - make sure you buy steppers that have threaded mounts, but don’t tighten the bottom two, or you will never be able to effectively tension the belts. Make sure you use thread lock, and cross your fingers it doesn’t fall apart on you.
No doubt if you buy all your components from the Openbuilds store, you won’t have a problem - but it’s meant to be open source, not ‘buy it all from me or it won’t work’
Becoming increasingly frustrated at the amount of bad engineering decisions that went into this design.
I would be interested to hear @Mark_Carew_OpenBuild 's take on how exactly we are meant to make this work, in practise.
