Hello All,
I’m trying to setup a new desktop 3D printer (Creality Ender-2) with smoothieware. Being new to this whole hobby and smoothie as well, I’m having an issue with the motion on the Z axis. As the specs for this printer are not published and the stepper motors used have no markings on the at all, I have to create my config.txt by actually measuring the linear motion of all axes. The steppers on the X,Y axes work as I would expect (per my configuration), but when it comes to the Z axis, given the same configuration parameters the linear distance per move is much less (G0 Z +10 yields a 2mm distance).
Assuming the motors are the same, should this not move the expected 10mm.
I verified that it was not coming from the board driver’s by swapping the Z and Y cables and repeating test. No change.
Here are my motor definitions in config.txt :
[[code]]
- Y Axis
beta_steps_per_mm 160
beta_step_pin 2.1
beta_dir_pin 0.11!
beta_en_pin 0.10
beta_current 1.0
beta_max_rate 30000
y_axis_max_speed 30000
panel.beta_jog_feedrate 6000
beta_min_endstop 1.26^
beta_min 0
beta_max 200
beta_max_travel 500
beta_fast_homing_rate_mm_s 50
beta_slow_homing_rate_mm_s 25
beta_homing_retract_mm 5
- Z Axis
gamma_steps_per_mm 160
gamma_step_pin 2.2
gamma_dir_pin 0.20
gamma_en_pin 0.19
gamma_current 1.0
gamma_max_rate 30000
z_axis_max_speed 30000
panel.gamma_jog_feedrate 6000
gamma_min_endstop 1.28^
gamma_min 0
gamma_max 200
gamma_max_travel 500
gamma_fast_homing_rate_mm_s 50
gamma_slow_homing_rate_mm_s 25
gamma_homing_retract_mm 5
[[/code]]
