Ms10105/moshidraw, it’s time to die. It is with grim satisfaction that I will de-solder you for parts. May you suffer in agony and pain for the last 2 years of pain you have put me through.
…"long live the “SMOOTHIE” :).
L’chaim!
hahaha! Go for it! Just finished mine! https://github.com/McNugget6750
@Timo_Birnschein yes, will probably go for something similar, but mine will be smaller, maybe the smallest to date? Will See how things turn out.
@Anton_Fosselius Cool! I can’t wait to see it. The only question I have is why smaller… there is plenty of space and design as well as manufacturability will certainly suffer. Mine is specifically designed for single sided plus wires but can be manufactured as dual sided with the exact same dimensions as the moshi board. But go for it! I’m looking forward to your results!
@Timo_Birnschein because I work with small embedded iot solutions.
So it’s hard for me to build big as i got a mental constraint.
I am tempted to pipe the gcode through gprs just because I can
I am not aiming for a factory grade production system. I am just fooling around. Right now I do not care about Latency, reliability and efficiency.
@Anton_Fosselius Sounds good! I’m looking forward to it!
