I’m currently designing a 1m x 1m x 1m 3D printer. I don’t currently own a smoothieboard but will absolutely be using it for my build. I really like what I’m seeing here. I was looking into some design features and had a question. I plan on having 4 extruders on this printer. I would like to be able to use them two ways. The first is the obvious way, a four color/filament extruder (one at a time). I would also like to spread out the 4 extruders to be able to do 4 simultaneous prints at a time. I understand that I can enslave the extruders steppers to the main stepper with hardware setup however, I would like to know if a module could be written to mirror the first extruder to the other extruders (sometimes 2, sometimes 3, sometimes 4, and sometimes 2 x 2) and possibly even operate it though G code.
I also plan on having 4 z-axis stepper motors to lift the bed. If the extruders are possible, I would like to do the same with the z-axis steppers to design a “real” auto bed leveling module.
Either way, I’ll figure it out. Just wanted to know if it will be possible to do it through firmware.
Thanks for your time,
David
