Mwahaha I always knew I would find something useful with this littlebits…
Testing how far down I have to push z until it registers.
Not looking good… Though it did registered after certain force and spits out number, the numbers are erratic not sure if it is because of the littlebits display or what…
Have the pad area pressing on the FSR be a little smaller. I find larger pads need more pressure to register the touch. Something like 50 to 60% the actual size of the FSR
preload set screw on the back of the FSR mount, to get the thing near a reliable reading pressure? then contact pushes the value into the range needed? maybe? ima big fan of preloading…
You should be pushing on a small point, not over the entire surface of the FSR. You may also want to put the hot end on a longer flex arm so that a larger linear motion equates to a smaller angular motion.
To adjust the amount of force needed to trigger the FSR, just change the value of the fixed resistor.
[update] @AlohaMilton pre loading the FSR seems to work more stable. It was squeezed to about 90% and all it takes to get to 92% is just a light tap on the nozzle. I’m hoping that would be enough to register as z trigger
Do you even know if the thing measuring voltage or resistance?
When you hook it up to the controller board, you’ll build a voltage divider with it and a fixed-value resistor. The voltage out of the divider will be determined by the ratio of the values of the two resistors, so you’ll be able to change the amount of force required to trigger by changing the other resistor.
As usual, littlebits are completely worthless for learning anything about how actual electronics work.
