My 280mm diameter piece of 6mm float glass has finally been cut.
My 280mm diameter piece of 6mm float glass has finally been cut. Now to fit to the printer, calibrate and do some testing
How you planning on fitting? Liked your build. Post pics when done if ya can.
thinking at the moment of mounting the glass to the aluminum heat spreader plate, fitting some pins to stop the glass from moving sideways and clips to hold it down. Will have a fiddle this afternoon after work
