Anyone got a source for a new one? I’ve just fitted a new 6mm wide belt, and when testing the run, I discovered the belt was running over the drive wheel on the stepper… it’s running over the cogs. Bugger, obviously the wrong pitch.
Measuring the old belt, it seems like it’s got 2.5mm pitch, and is 4.87mm wide (prob 5mm).
Thanks, guys. I’d measured the pitch with a vernier, and it came out to 2.5mm, so I ordered some from http://ooznest.co.uk/3D-Printer-Mechanical-Parts/Belts-Pulleys/T2.5-Pulley-Timing-Belt-Kits. After reading your replies, I’ll order some 2mm as well. It’ll come in handy, one day! I have the standard board, there’s no-where to set the change of pitch, even with new pulleys, it won’t be the same? I’ll upgrade it sometime, when I can figure out the best way (read easiest…).
Have to say, Google hasn’t got this groups thing right, it needs a revamp…
Many thanks for the pointers, folks, seems like I’ll be up & running in a couple of days, now.
Just fitted a GT2 belt to my K40. It’s running over the cogs on the pulley every 10mm, or thereabouts, obviously not the correct pitch for this standard machine. The pitch is slightly more than 2mm, but not 2.5! I’m thinking it’s going to be imperial, a standard practice for China, the cheapest… So I’m now on the lookout for 3/32" pitch x 3/16", which is why it measure 4.8mm width, not 5. With the GT2, I burnt an 80mm square and got 78.6 on the X-axis.
If I fit a new GT2 pulley, would it end up correct, again (pulleys are not my strongest subject…) ?
I could always try it.
Surprised others haven’t had this problem…
Ain’t life grand?
Just came to the same conclusion, Konstantinos! The confusion I’ve wrought might well be due to the many different makers of these machines… I’m pretty sure some might take GT2 belts, but mine sure doesn’t, unless I butcher it…! Thanks for your input. Just for a laugh, I might try a GT2 pulley on it, to see if the belt/pulley combo will work, pretty sure it’ll be undersized. Ho hum! Onwards & upwards!
Yes, I can do that easily in Mach3, but I have the stock board using that bloody awful LaserDrw. No options to change anything. I’m pretty sure I’d have to flash it. That’s too much trouble. I may upgrade with a TB6560 board I have, or Arduino. Eventually.
Just found some suppliers of MXL belts in the UK. So should be up & running in a few days…
