My DIY CNC project - The gantry side plates arrived today :-) Always exiting
My DIY CNC project - The gantry side plates arrived today :slight_smile:
Always exiting when new parts arrives - did a test mount and all seems to be as planned :slight_smile:
10mm alu (5754) made using water cutter.
I`m going to order the motor/bearing mounts from the same place.
Seems like I`ll get the controller early next week and the power supply and stepper motor is on their way :slight_smile:
This is great fun :slight_smile:
That quick?
@raykholo yes, already in Norway :slightly_smiling_face:
The gantry I`m going to build. The z-axis is almost ready
You have access to equipment some of us can only dream of :frowning:
Because I use Fusion 360 for my designs, I hope to use the Fusion Cam together with my CNC.
I`m going to use the Cohesion3D ReMix as the controller, running smoothieware.
Anyone using Fusion 360 CAM + smoothie controller? What is the best software to combine with Fusion for CNC control?
