My first cut on my Ooznest OX machine :).
My first cut on my Ooznest OX machine :). Machine is a double belted 1000mm x 1000mm OX and the board is 660mm x 95mm x 19mm with the cut out being 5mm deep. This was done with a 1/8" wood bit with 2.5mm passes with a total cut time was 35 minutes. You will see in the video my mistake with the zeroing of the Z which I ended up sanding out.
Boost that speed, shouldn’t take more then like 8 minutes
Just getting familiar with the machine and CNCing in general. Higher speeds will come, tho not to concerned with the speed of the job atm as long as my spindle speed/feed rate is correct and won’t start a fire
