My Kossel is Autoleveling now - Force Sensors below glass plate.
My Kossel is Autoleveling now - Force Sensors below glass plate. Only Problem is when the Nozzel pushes on the plate outside the sensor triangle…
Suggestions for that?
Sounds like one or more FSR’s aren’t triggering. First verify they’re wired on parallel. Then check that each one triggers by removing the plate and press each individually.
@Mark_Fuller , they trigger OK, but the force to lever the plate up when pressing the rim is quite low.
