My LED prototypes in chronological order from left to right.
1st prototype - White 5mm LEDs running on 2 AA batteries. Constant on. 0 control.
2nd prototype - 2 5mm RGB analog LEDs running on PWM wired in parallel. Color fade effect. Some control.
3rd prototype - 7 5mm RGB analog LEDs running on PWM wired in parallel. Color fade effect. Some control. All LEDs change simultaneously.
4th prototype - first use of digital LEDs. 25 pixel LED strip running off an arduino nano. Multiple effects possible. Individual LEDs can be addressed. No control over pattern.
5th prototype - WS2812B LEDs running off of an arduino gemma and lithium polymer battery. Multiple effects possible. Individual LEDs can be addressed. No control over patter.
6th prototype - first use of custom PCB with embeded microphone. Running off a lithium polymer battery. LEDs react to sound around them.
7th prototype and first fully functional unit - strip of WS2812B LEDs running off a newer custom PCB and lithium polymer battery running 5 different patterns. Pushbutton and modified program allow easy scrolling throught patterns and sound reactive pattern is also available.
8th prototype unit will make use of 3D printed parts for cosmetic and durability purposes.
Nice progression and documentation.
Thank you @marmil ​ it all started with that crazy idea. I was gonna throw away a tie and i was like “hey why not put lights in jt?”
