My new 50 watt tube from laser depot arrived today in great condition....packaged well
My new 50 watt tube from laser depot arrived today in great condition…packaged well and a great price…it will be installed tomorrow!
Glad to hear it. Maybe I’ll go for one next time.
Does the 50w tube drop in to the chassis of the k40? Or are you working off the larger chassis
LightObject.com sells a metal case extension that lengthens the tube area so that you can use a 50W tube on a K40. Tube upgrade would also require a PSU upgrade. However, I think it is worth it as most K40’s are really only 30-35 watts, and most ebay machines that say they are 50W are actually just 35-40W tubes that they are over driving to produce the higher output, which dramatically shortens the tube life.
@funinthefalls …the max milli amps on the tube is 18…I think the power supply will be fine…the max output of the power supply is 26 mA’s
@Alex_Krause …I’m working with a bigger machine…but Anthony is right…they overdrive the machines they sell.
What happened to the tube in your machine
@Phillip_Conroy …it’s fine…like Anthony said I think it’s a 40 watt tube not a 50 watt like advertised…the tube that came in it is 800 mm long and a true 50 watt is 990mm long.
@Phillip_Conroy …the reason I bought the new tube is tube depot had a sale…I got it for 225.00…so I figured I would get it while on sale.
Would you be interested in selling the 40W tube?
Sure…I have all the packing material…it’s a reci tube…says max watts 48.
Do you still have the reci for sale?
@funinthefalls … yeah…I’ll let you know when I get the puri installed…looks like it’s going to be Wednesday before the power supply gets here.
Thanks.
@funinthefalls …you bet man…I haven’t forgotten about you man…
I just figured I would not take the chance and go ahead and get the right size power supply.
