My new Prusa i3
http://www.youtube.com/watch?v=pZ_sI7N1zxw
Where did you source the aluminum frame? I’m looking to get 2 of them. Just don’t want to pay $100 for them.
I sourced the frame from a local engineering company for £50! It was laser cut so needed a little smoothing by hand, but wasn’t a problem. Have you tried sourcing locally, saving delivery costs? I just emailed the .dxf file to a few companies!
Cheapest I found was $50 + Material cost, which they wanted something like $40 for. I just can’t see paying $90+ for an aluminum frame.
If you missed out the Prusa name (criminal I know!) then why not just buy the ali and hand cut/sand/dremel the frame?
@ThantiK make box frame?
you get great print quality looking at the parts in video. what setup you use
@Karan_Chaphekar as in settings, software?
@John_Ridley Not seeing any movement in the ali frame as of yet, especially with not having to throw a stepper motor side to side on the X-axis!
@John_Ridley Without the X-axis causing the wobble at height you’d have to have a lot of speed on Y-axis to rock the 6mm ali frame!
@John_Ridley None as long as you have your retraction settings spot on! You maybe can’t extrude as fast as you’d over pressure the bowden tube, but there again in a geared extruder you’d just strip the filament!
@John_Ridley I agree, I love the way the Prusa i3 ali has hardly any nuts, instead all the holes are threaded in the frame and parts are designed for exact bolt length.
I will be printing one of your bowdens for mine.
Nice print after moving away from calibration cubes http://www.thingiverse.com/derivative:54275
@John_Ridley I would try that model, no taxing parts for the printer, just requires a lot of cooling!
