My printer has printed its first objects and I'm super happy. Sharp corners.
My printer has printed its first objects and I’m super happy.
Sharp corners. Good layer bonding. No missed steps. Good results with no heated bed.
Steps per mm are only off a tiny bit
Mike did you ever use the Prusa calculator I sent you a while back? It help me out with this issue.
I did. I have to admit I just find some calibration settings onLine and used them so I can’t complain to much.
I will just need to put in the time fine tuning it.
What temperature is every one using for pla? I ran these at 210
It depends on the filament, you need to dial it in, some need 185 and others 215.
Humm interesting the side finish matches the parts I got from you. Also at 210 I hear no crackling and can solve it threw by hand very easy.
Ill bump it down to 190 and run a cube tonight.
