enhydra
(Kurt Meister)
My Printrbot play and simple metals run very well. But I don’t like the procedure of adjusting the distance between the nozzle and the printbed.
Is there a firmware availlable for ref F4 and F5, which allows to set the z compensation via LCD and dial?
No, we’ve always used mcodes for this. Sorry! I’ll ask Laine if there is room to add it.
Brook
Actually, there is…
Marin supports a feature called babystepping which allows you to adjust the nozzle height while the print is running using the LCD and dial.
