need help with code, example code is http://pastebin.com/9g0f73jE. I m having hard time with pir sensor with Adafruit NeoPixel library. when i put some code topdown(); function (line 39) , the serial monitor keeping tell me the pir is HIGH all the time…
if put the comment topdown(); function the serial monitor is running normally.
motion ended at 0 sec
motion ended at 1 sec
motion ended at 2 sec
I am not sure what is the cause pir is HIGH.
Should I add some delay function?
