Need quick help again.
Need quick help again. What do these mean in terms of + - like where does the ground go? And where does the led strip + add Power supply - go? It’s a motion sensor btw
What you have is a 12v switch, the motion sensor being the thing that determines is the switch is on or off. L is the positive voltage input. Load is the positive voltage output. N is the neutral/common/negative for both input and output connections.
Ok thanks a lot. I guessed correctly, but just wanted to make sure.
