Need some help defining my end stops.
Need some help defining my end stops. I am using the latest version of Marlin and I have my endstop wires hooked up to the common and the normally open connections on my endstops and the wires that go to the ramps 1.4 board are connected to the ground and signal pins. I am have a little trouble discerning what the difference is between #ifndef section and the ifdef section so I don’t know which ones should be commented out and which ones shouldn’t. Below is what the settings are currently which is the default from when I downloaded the firmware. Any help would be appreciated. TIA
// coarse Endstop Settings
#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
#ifndef ENDSTOPPULLUPS
// fine Enstop settings: Individual Pullups. will be ignored if ENDSTOPPULLUPS is defined
// #define ENDSTOPPULLUP_XMAX
// #define ENDSTOPPULLUP_YMAX
// #define ENDSTOPPULLUP_ZMAX
// #define ENDSTOPPULLUP_XMIN
// #define ENDSTOPPULLUP_YMIN
// #define ENDSTOPPULLUP_ZMIN
#endif
#ifdef ENDSTOPPULLUPS
#endif
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins.
const bool X_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Y_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Z_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool X_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Y_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Z_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
//#define DISABLE_MAX_ENDSTOPS
//#define DISABLE_MIN_ENDSTOPS
// Disable max endstops for compatibility with endstop checking routine
#if defined(COREXY) && !defined(DISABLE_MAX_ENDSTOPS)
#endif
There is some information here about configuring end stops:
http://airtripper.com/1145/marlin-firmware-v1-basic-configuration-set-up-guide/
It is usually recommended to have the switches normally closed. It would avoid an axis crash if an end stop switch wire becomes disconnected.
Thanks Mark. That makes sense. And thanks for the link.
