Need some help with Focal Length!
UPDATE 7-23-2015 2:26 PM CST
I have rechecked my alignment, and noticed a major issue!
close to 0,0 I was getting two or three burns rather than a single burn.
It turned out, the 1st Mirror was scattering the beam as it was hitting
very close to the edge, I fixed that and re-aligned all mirrors.
Suddenly I can cut 3mm(1/8") MDF without any issues!!
Will continue to test but it seems that this fixed my issue.
Thank you guys for your comments, it HELPED me!
------------------------------------- End of Update -----------------------------------
My K40 is upgraded with the LightObject DSP controller KIT.
It came with an air-assist nozzle so the whole assemble was changed with the one from LightObject. The Focus lens box states F=50.8, I am assuming 50.8 mm, from the concave portion (being up and straight side facing down)
I am getting uneven cuts or more like, closer to origin good
cut-through and moving outwards to Max_X,Max_Y it doesn’t cut-through especially when using wood.
am I looking at an uneven bed scenario that is causing the wood to
be out of the focus range? or is it a different matter?
My initial test shows the bed is level +/- 2mm not sure if that equates to A LOT or acceptable in the world of optics.
Referencing http://www.parallax-tech.com/faq.htm
Depth of field section, I can’t calculatethe +/- d value as some of the
variables are unknown to me especially that it is a Chinese laser tube!
Thanks for your feedback.
