New effector, much speed
Good work :slight_smile:
What do you print on the video? Any problems with adhesion in this big element?
I’m printing an LCD and button panel for a Hydroponics system. Usig G29 and G33, I’m not having any trouble with adhesion. Well, I do see there are some spots that are crapping out, but I think that is due to finger marks, not errors in the bed height. Here is my latest probe data. It’s within 0.2 mm across the bed: http://review.thing-printer.com/?key=WBN0CIE9TK98XMNPYST0
My last print was element 165mm width and two corners were not stick properly to the bed. Now I test primafix and it makes adhesion much better. But I must change design of heated bed and implememt bed probing.
What is your probe setup? Can we get BLTouch support added?
Wiley on http://replicape.slack.com has BLTouch working. I can possibly make it into a plug-in if need, but it should work with just the right setup…
