New extruder head on Smoothieboard Delta printer, not able to recalibrate
I’m an alumni of FRC 3574, and we have a Delta-style 3d printer, powered by a Smoothieboard, that went out of commission some time ago due to a broken thermister. I’ve replaced the old head entirely, with an e3D v6 extruder head, and wired it all in. I can confirm that it heats up as it should, and measures its own temperatures fine, but now the issue is that the head is a few millimeters longer than the old one, so I need to reset the distance from the head while homed to the bed to be shorter. If I try to jog it down to where i need it to be, and use the “Set Z0” option in the menu, it doesn’t appear to do anything. I also cannot run a G32 without the head pressing onto the glass bed and causing the timing belt to jump, because it just won’t stop.
This head doesn’t have a probe on it, but but the bed rests on three pressure sensors, placed on the center of each of the three bars that form the base of the printer. I feel like part of the issue may be that they’re not plugged in properly, but as this printer was gifted to us, and I can’t find any instructions or documentation on these, I can’t say for sure, and the board they plug into is not the smoothieboard, but some other device that I can’t find a name on.
Basically, I just need to figure out how to tell the printer where the bed is now, with a longer head on it. Below is my config script, so hopefully that will help. I have pictures as well but I’m not sure of how to add them into this post.
[[code]]# NOTE Lines must not exceed 132 characters
  1. Robot module configurations : general handling of movement G-codes and slicing into moves
default_feed_rate 4000 # Default rate ( mm/minute ) for G1/G2/G3 moves
default_seek_rate 4000 # Default rate ( mm/minute ) for G0 moves
mm_per_arc_segment 0.5 # Arcs are cut into segments ( lines ), this is the length for
# these segments. Smaller values mean more resolution,
# higher values mean faster computation
#mm_per_line_segment 0.5 # Lines can be cut into segments ( not useful with cartesian
# coordinates robots ).
delta_segments_per_second 100 # for deltas only same as in Marlin/Delta, set to 0 to disable
# and use mm_per_line_segment
Arm solution configuration : Cartesian robot. Translates mm positions into stepper positions
arm_solution linear_delta # selects the delta arm solution
alpha_steps_per_mm 100 # Steps per mm for alpha stepper
beta_steps_per_mm 100 # Steps per mm for beta stepper
gamma_steps_per_mm 100 # Steps per mm for gamma stepper
arm_length 400.0 # this is the length of an arm from hinge to hinge
arm_radius 189.0 # this is the horizontal distance from hinge to hinge
# when the effector is centered
  1. Planner module configuration : Look-ahead and acceleration configuration
planner_queue_size 32 # DO NOT CHANGE THIS UNLESS YOU KNOW EXACTLY WHAT YOU ARE DOING
acceleration 3000 # Acceleration in mm/second/second.
acceleration_ticks_per_second 1000 # Number of times per second the speed is updated
junction_deviation 0.05 # Similar to the old "max_jerk", in millimeters,
# Lower values mean being more careful, higher values means being
# faster and have more jerk
#minimum_planner_speed 0.0 # sets the minimum planner speed in mm/sec
  1. Stepper module configuration
microseconds_per_step_pulse 1 # Duration of step pulses to stepper drivers, in microseconds
base_stepping_frequency 100000 # Base frequency for stepping
  1. Cartesian axis speed limits
x_axis_max_speed 30000 # mm/min
y_axis_max_speed 30000
mm/min
z_axis_max_speed 30000 # mm/min
  1. Stepper module pins ( ports, and pin numbers, appending "!" to the number will invert a pin )
alpha_step_pin 2.0 # Pin for alpha stepper step sign
al
alpha_dir_pin 0.5 # Pin for alpha stepper direction
alpha_en_pin 0.4 # Pin for alpha enable pin
alpha_current 1.5 # X stepper motor current
alpha_max_rate 30000.0 # mm/min
beta_step_pin 2.3 # Pin for beta stepper step signal
beta_dir_pin 0.22 # Pin for beta stepper direction
beta_en_pin 0.21 # Pin for beta enable
beta_current 1.5 # Y stepper motor current
beta_max_rate 30000.0 # mm/min
gamma_step_pin 2.1 # Pin for gamma stepper step signal
gamma_dir_pin 0.11 # Pin for gamma stepper direction
gamma_en_pin 0.10 # Pin for gamma enable
gamma_current 1.5 # Z stepper motor current
gamma_max_rate 30000.0 # mm/min
  1. Serial communications configuration ( baud rate default to 9600 if undefined )
uart0.baud_rate 115200 # Baud rate for the default hardware serial port
second_usb_serial_enable false # This enables a second usb serial port (to have both pronterface
# and a terminal connected)
#leds_disable true # disable using leds after config loaded
#msd_disable false # disable the MSD (USB SDCARD) when set to true
#dfu_enable false # for linux developers, set to true to enable DFU
#watchdog_timeout 10 # watchdog timeout in seconds, default is 10, set to 0 to disable the watchdog
  1. Extruder module configuration
extruder.hotend.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend.steps_per_mm 475 # Steps per mm for extruder stepper
extruder.hotend.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend.acceleration 500 # Acceleration for the stepper motor, as of 0.6, arbitrary ratio
extruder.hotend.max_speed 3000 # mm/s
extruder.hotend.step_pin 2.8 # Pin for extruder step signal
extruder.hotend.dir_pin 2.13 # Pin for extruder dir signal
extruder.hotend.en_pin 4.29 # Pin for extruder enable signal
  1. extruder offset
#extruder.hotend.x_offset 0 # x offset from origin in mm
#extruder.hotend.y_offset 0 # y offset from origin in mm
#extruder.hotend.z_offset 1 # z offset from origin in mm
  1. firmware retract settings when using G10/G11, these are the defaults if not defined, must be defined for each extruder if not using the defaults
#extruder.hotend.retract_length 3 # retract length in mm
#extruder.hotend.retract_feedrate 45 # retract feedrate in mm/sec
#extruder.hotend.retract_recover_length 0 # additional length for recover
#extruder.hotend.retract_recover_feedrate 8 # recover feedrate in mm/sec (should be less than retract feedrate)
#extruder.hotend.retract_zlift_length 0 # zlift on retract in mm, 0 disables
#extruder.hotend.retract_zlift_feedrate 6000 # zlift feedrate in mm/min (Note mm/min NOT mm/sec)
delta_current 1.0 # First extruder stepper motor current
  1. Second extruder module configuration example
#extruder.hotend2.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
#extruder.hotend2.steps_per_mm 140 # Steps per mm for extruder stepper
#extruder.hotend2.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
#extruder.hotend2.acceleration 500 # Acceleration for the stepper motor, as of 0.6, arbitrary ratio
#extruder.hotend2.max_speed 50 # mm/s
#extruder.hotend2.step_pin 2.8 # Pin for extruder step signal
#extruder.hotend2.dir_pin 2.13 # Pin for extruder dir signal
#extruder.hotend2.en_pin 4.29 # Pin for extruder enable signal
#extruder.hotend2.x_offset 0 # x offset from origin in mm
#extruder.hotend2.y_offset 25.0 # y offset from origin in mm
#extruder.hotend2.z_offset 0 # z offset from origin in mm
#epsilon_current 1.5 # Second extruder stepper motor current
  1. Laser module configuration
laser_module_enable false # Whether to activate the laser module at all. All configuration is
# ignored if false.
#laser_module_pin 2.5 # this pin will be PWMed to control the laser. Only P2.0 - P2.5, P1.18, P1.20, P1.21, P1.23, P1.24, P1.26, P3.25, P3.26
# can be used since laser requires hardware PWM
#laser_module_maximum_power 1.0 # this is the maximum duty cycle that will be applied to the laser
#laser_module_minimum_power 0.0 # This is a value just below the minimum duty cycle that keeps the laser
# active without actually burning.
#laser_module_default_power 0.8 # This is the default laser power that will be used for cuts if a power has not been specified. The value is a scale between
# the maximum and minimum power levels specified above
#laser_module_pwm_period 20 # this sets the pwm frequency as the period in microseconds
  1. Hotend temperature control configuration
temperature_control.hotend.enable true # Whether to activate this ( "hotend" ) module at all.
# All configuration is ignored if false.
temperature_control.hotend.thermistor_pin 0.23 # Pin for the thermistor to read
temperature_control.hotend.heater_pin 2.7 # Pin that controls the heater
temperature_control.hotend.thermistor Semitec #
#temperature_control.hotend.beta 4066 # or set the beta value
temperature_control.hotend.set_and_wait_m_code 109
temperature_control.hotend.designator T #
#temperature_control.hotend.max_temp 230 # Set maximum temperature - Will prevent heating above 300 by default
#temperature_control.hotend.min_temp 0 # Set minimum temperature - Will prevent heating below 0 by default
#temperature_control.hotend.p_factor 13.7 # permanently set the PID values after an auto pid
#temperature_control.hotend.i_factor 0.097 #
#temperature_control.hotend.d_factor 24 #
#temperature_control.hotend.max_pwm 64 # max pwm, 64 is a good value if driving a 12v resistor with 24v.
  1. Hotend2 temperature control configuration
#temperature_control.hotend2.enable true # Whether to activate this ( "hotend" ) module at all.
#temperature_control.hotend2.thermistor_pin 0.25 # Pin for the thermistor to read
#temperature_control.hotend2.heater_pin 1.23 # Pin that controls the heater
#temperature_control.hotend2.thermistor EPCOS100K #
#temperature_control.hotend2.beta 4066 # or set the beta value
#temperature_control.hotend2.set_m_code 104 #
#temperature_control.hotend2.set_and_wait_m_code 109 #
#temperature_control.hotend2.designator T1 #
#temperature_control.hotend2.p_factor 13.7 # permanently set the PID values after an auto pid
#temperature_control.hotend2.i_factor 0.097 #
#temperature_control.hotend2.d_factor 24 #
#temperature_control.hotend2.max_pwm 64 # max pwm, 64 is a good value if driving a 12v resistor with 24v.
temperature_control.bed.enable false
temperature_control.bed.thermistor_pin 0.24
temperature_control.bed.heater_pin 2.5
temperature_control.bed.thermistor Honeywell100K #
#temperature_control.bed.beta 4066 # or set the beta value
temperature_control.bed.set_m_code 140
temperature_control.bed.set_and_wait_m_code 190
temperature_control.bed.designator B #
#temperature_control.bed.bang_bang false # set to true to use bang bang control rather than PID
#temperature_control.bed.hysteresis 2.0 # set to the temperature in degrees C to use as hysteresis
  1. when using bang bang
  1. Switch module for fan control
switch.fan.enable true
switch.fan.input_on_command M106
switch.fan.input_off_command M107
switch.fan.output_pin 2.5
switch.fan.output_type pwm # pwm output settable with S parameter in the input_on_comand
#switch.fan.max_pwm 255 # set max pwm for the pin default is 255
#switch.misc.enable true #
#switch.misc.input_on_command M42 #
#switch.misc.input_off_command M43 #
#switch.misc.output_pin 2.4 #
#switch.misc.output_type digital # just an on or off pin
  1. automatically toggle a switch at a specified temperature. Different ones of these may be defined to monitor different temperatures and switch different swithxes
  1. useful to turn on a fan or water pump to cool the hotend
#temperatureswitch.hotend.enable true #
#temperatureswitch.hotend.designator T # first character of the temperature control designator to use as the temperature sensor to monitor
#temperatureswitch.hotend.switch misc # select which switch to use, matches the name of the defined switch
#temperatureswitch.hotend.threshold_temp 60.0 # temperature to turn on (if rising) or off the switch
#temperatureswitch.hotend.heatup_poll 15 # poll heatup at 15 sec intervals
#temperatureswitch.hotend.cooldown_poll 60 # poll cooldown at 60 sec intervals
  1. Switch module for spindle control
#switch.spindle.enable false #
  1. Endstops
endstops_enable true # the endstop module is enabled by default and can be disabled here
delta_homing true # forces all three axis to home a the same time regardless of
# what is specified in G28
alpha_min_endstop nc #
alpha_max_endstop 1.25^ # add ! to invert pullup if switch is NO to ground
alpha_homing_direction home_to_max # Home up
alpha_max 0 #
beta_min_endstop nc #
beta_max_endstop 1.29^ #
beta_homing_direction home_to_max #
beta_max 0 #
gamma_min_endstop nc #
gamma_max_endstop 1.27^ #
gamma_homing_direction home_to_max #
gamma_max 230 #
alpha_fast_homing_rate_mm_s 200 # homing feedrates in mm/second
beta_fast_homing_rate_mm_s 200 #
gamma_fast_homing_rate_mm_s 200 #
alpha_slow_homing_rate_mm_s 20 #
beta_slow_homing_rate_mm_s 20 #
gamma_slow_homing_rate_mm_s 20
alpha_homing_retract_mm 5 # retract/bounce distance after homing in mm
beta_homing_retract_mm 5 #
gamma_homing_retract_mm 5 #
alpha_trim 0 # software trim for alpha stepper endstop (in mm)
beta_trim 0 # software trim for beta stepper endstop (in mm)
gamma_trim 0 # software trim for gamma stepper endstop (in mm)
  1. optional enable limit switches, actions will stop if any enabled limit switch is triggered (all are set for delta)
#alpha_limit_enable false # set to true to enable X min and max limit switches
#beta_limit_enable false # set to true to enable Y min and max limit switches
#gamma_limit_enable true # set to true to enable Z min and max limit switches
#move_to_origin_after_home true # move XY to 0,0 after homing
#endstop_debounce_count 100 # uncomment if you get noise on your endstops
  1. optional Z probe
zprobe.enable true # set to true to enable a zprobe
zprobe.probe_pin 1.28!^ # pin probe is attached to if NC remove the !
zprobe.slow_feedrate 5 # mm/sec probe feed rate
#zprobe.debounce_count 100 # set if noisy
zprobe.fast_feedrate 100 # move feedrate mm/sec
zprobe.probe_height 10 # how much above bed to start probe
#gamma_min_endstop nc # normally 1.28. Change to nc to prevent conflict,
  1. associated with zprobe the leveling strategy to use
leveling-strategy.delta-calibration.enable true # basic delta calibration
leveling-strategy.delta-calibration.radius 100 # the probe radius
leveling-strategy.delta-calibration.initial_height 50 # height above bed to stop initial move
  1. kill button (used to be called pause) maybe assigned to a different pin, set to the onboard pin by default
kill_button_enable false # set to true to enable a kill button
#kill_button_pin 2.12 # kill button pin. default is same as pause button 2.12 (2.11 is another good choice)
  1. Panel
panel.enable true # set to true to enable the panel code
panel.lcd viki2 # set type of panel
panel.spi_channel 0 # set spi channel to use P0_18,P0_15 MOSI,SCLK
panel.spi_cs_pin 0.16 # set spi chip select
panel.encoder_a_pin 3.25!^ # encoder pin
panel.encoder_b_pin 3.26!^ # encoder pin
panel.click_button_pin 1.30!^ # click button
panel.a0_pin 2.11 # st7565 needs an a0
#panel.contrast 8 # some panels need contrast set, this is for viki2
#panel.encoder_resolution 4 # number of clicks to move 1 item
#panel.buzz_pin 1.31 # pin for buzzer (use red led OR buzzer not both)
panel.red_led_pin 1.31 # pin for red led on viki2
#panel.blue_led_pin 1.23 # pin for blue led on viki2 (5 driver can't use this)
#panel.back_button_pin 1.30!^ # optionally using the red button as a back button (NOT available on 5 driver)
  1. setup for external sd card on the viki2
panel.external_sd true # set to true if there is an extrernal sdcard on the panel
panel.external_sd.spi_channel 0 # set spi channel the sdcard is on
panel.external_sd.spi_cs_pin 0.27 # set spi chip select for the sdcard
panel.external_sd.sdcd_pin 0.28!^ # sd detect signal (set to nc if no sdcard detect)
  1. Example of a custom menu entry, which will show up in the Custom entry.
  1. NOTE _ gets converted to space in the menu and commands, | is used to separate multiple commands
custom_menu.power_on.enable true
custom_menu.power_on.name Power_on
custom_menu.power_on.command M80
custom_menu.power_off.enable true
custom_menu.power_off.name Power_off
custom_menu.power_off.command M81
custom_menu.G28.enable true
custom_menu.G28.name G28
custom_menu.G28.command G28
custom_menu.G92.enable true
custom_menu.G92.name G92
custom_menu.G92.command G92 Z0
custom_menu.M114.enable true
custom_menu.M114.name M114
custom_menu.M114.command M114
custom_menu.G32.enable true
custom_menu.G32.name G32
custom_menu.G32.command G32
custom_menu.M306.enable true
custom_menu.M306.name M306_Z02
custom_menu.M306.command M306_Z0
custom_menu.GoZ1.enable true
custom_menu.GoZ1.name G0_Z1
custom_menu.GoZ1.command G0_Z1
custom_menu.M500.enable true
custom_menu.M500.name M500
custom_menu.M500.command M500 #
custom_menu.M106.enable true
custom_menu.M106.name Fan off
custom_menu.M106.command M106
custom_menu.M107.enable true
custom_menu.M107.name Fan off
custom_menu.M107.command M107
  1. Only needed on a smoothieboard
currentcontrol_module_enable true
return_error_on_unhandled_gcode false #
  1. network settings
network.enable false # enable the ethernet network services
network.webserver.enable true # enable the webserver
network.telnet.enable true # enable the telnet server
network.ip_address auto # use dhcp to get ip address
[[/code]]
Thank you in advance for reading this, any help is greatly appreciated.
-Jesse
You probably want to change your gamma_max value, see the delta documentation page.
