New part In aluminium
40ipm
100mills pass
Looks nice. What coolant fluid are you using? How many watts is the spindle?
Spindle 2.2K Watt (220V)
For the cooling is mc master
is water soluble synthetic oil
@jlauer any new word on V Carving for easel?
You mean for ChiliPeppr?
@jlauer yes sorry that is exactly what I meant.
Ok, that’s what I thought. But, what do you mean by v-carving?
I have recently swicthed to chilipeppr I started out using easel. I like chilipeppr much better but I have trouble with files not loading and it is saying there isnt enough memory. I was told it would put it in the computers memory and run it from there. But for some reason it will not.
How big are your files? I find that over 5MB things get really sloooooow. I try to stay under 1MB. Can you reduce the detail? I find that if I make a larger tolerance in Fusion 360 I get longer line segments, which creates way less Gcode.
I see what you mean, I was trying to send code for some text, just a name in block lettering 3.5" x 12", very little detail. I wasnt sure of how many lines of code it was but I do believe it was bigger than 5MB. Although I am not sure why it would have been that large. I am still new and do not know how to change the tolerance. I was using JSCut.
JSCut is notorious for creating massively large Gcode. Everyone has had that problem. I use Fusion 360 now for almost all of my Gcode creation. It’s free for makers.
Maybe I should be using Fusion 360. By the way thank you for taking time to help me out.
Awesome, I will try that. Thanks again.
