New rotary test, this one with laser on. Still work to do for getting steps and placement correct. - YouTube special thanks to @Wolfmanjm for the ABC axis support and new laser firmware #yearofthelaser
Nice!
very cool, I suppose i’ll have to design up a rotary system to use up the short 15x15 misumi rails from my old delta printer. I was really trying to tell myself that I did not need a rotary Axis, but it’s too cool to pass up.
@Ariel_Yahni_UniKpty I’m right behind you. Looks like you have a JTechphotonics laser on your setup. Are you using TinyG or something else? What did you use to convert Gcode for the A axis? I’ve been looking at cnc wrapper, it seems pretty easy to use.
@Matt_Herrera yes it is from them
. Im using smoothie and this was the first test i did with the newest build for ABC axis. I just converted Y axis into A and send it via Laserweb.
@Ariel_Yahni_UniKpty Sweet!
Any recommendations for a DIY rotary tool? I have access to a laser and 3D printers (aside from all “normal” power tools)…
@CescoAiel this is the one I use Laser Rotary Attachment found on #Thingiverse Laser Rotary Attachment by ddanijell - Thingiverse
Thanks! I searched thingiverse, but searching and finding isn’t the same there!
