#K40LPS
Newest lightning strike:
I wanted to test what happens with a fully open circuit. Notice the acrylic barrier in the gap.
This may be what was wrong with this supply?
#K40LPS
Well that was interesting.
What was the end of the HV lead doing at that time? Any corona?
And how about the mA-meter. (Both were just out of frame.)
Just another reason to be sure everyone’s K40’s have solid grounding. (As shipped from the factory, they are shit.)
To aid in your experiments, @donkjr , you may want to put a parallel resistor across you mA meter. That way, instead of 0-30mA you could change the range to 0-300ma or even 0-3000mA. (The resistor math is an exercise left to the student.)
@Nate_Caine The HV lead was just connected to the black plastic post and it had no corona. The meter reads 5-10 ma. Yes I could configure a multi-range amp meter …
Grounding is critical and this amount of energy dictates an interlock on the laser compartment door …
Whoa, would not have expected that to happen. Very interesting. Thanks for your work Don.
