next faise for the Z probe
ok, the npn probe is conected. the v+ and ‘ground’ are conected to the boards power supply rails, theres a 150/100k resiter set up, and the sencer output is connected to pin1.22
untriggered the light is on, on the sencor, and zero volts on the out put
triggered the sencer light goes out and theres +4.89v
M119 returns a ‘0’ for untriggerred and a ‘1’ for triggered.
but…G32 starts, homes and then goes to the first point of a three point auto bed leval, the head goes down, the sencer light goes out, and the head then triggers the Zmin end stop.
on pronterface, a M999 is required, after doing so theres a 30 second pause before anything will execute. if you try more than once all comands are executed after the 30 second pause.(as in 5 or 6 moves will exexute) where as any other time pronterface only returns 2 lines max.
so what do i try next?
# Endstops
endstops_enable                              true             # the endstop module is enabled by default and can be disabled here
#corexy_homing                               false            # set to true if homing on a hbit or corexy
alpha_min_endstop                            1.24^!          # add a ! to invert if endstop is NO connected to ground
alpha_max_endstop                            nc            # NOTE set to nc if this is not installed
alpha_homing_direction                       home_to_min      # or set to home_to_max and set alpha_max
alpha_min                                    0                # this gets loaded after homing when home_to_min is set
alpha_max                                    180              # this gets loaded after homing when home_to_max is set
beta_min_endstop                             1.26^!           #
beta_max_endstop                             nc            #
beta_homing_direction                        home_to_min      #
beta_min                                     0                #
beta_max                                     200              #
gamma_min_endstop                            1.28^!            #
gamma_max_endstop                            nc        #
gamma_homing_direction                       home_to_min      #
gamma_min                                    0                #
gamma_max                                    110             #
# optional order in which axis will home, default is they all home at the same time,
# if this is set it will force each axis to home one at a time in the specified order
homing_order XYZ # x axis followed by y then z last
# optional enable limit switches, actions will stop if any enabled limit switch is triggered
alpha_limit_enable true # set to true to enable X min and max limit switches
beta_limit_enable true # set to true to enable Y min and max limit switches
gamma_limit_enable true # set to true to enable Z min and max limit switches
alpha_fast_homing_rate_mm_s 50 # feedrates in mm/second
beta_fast_homing_rate_mm_s 50 # "
gamma_fast_homing_rate_mm_s 4 # "
alpha_slow_homing_rate_mm_s 25 # "
beta_slow_homing_rate_mm_s 25 # "
gamma_slow_homing_rate_mm_s 2 # "
alpha_homing_retract_mm 3 # distance in mm
beta_homing_retract_mm 3 # "
gamma_homing_retract_mm 0.5 # "
#endstop_debounce_count 100 # uncomment if you get noise on your endstops, default is 100
# optional Z probe
zprobe.enable true # set to true to enable a zprobe
zprobe.probe_pin 1.22^ # pin probe is attached to if NC remove the !
zprobe.slow_feedrate 2 # mm/sec probe feed rate
#zprobe.debounce_count 100 # set if noisy
zprobe.fast_feedrate 20 # move feedrate mm/sec
zprobe.probe_height 5 # how much above bed to start probe
gamma_min_endstop 1.28^! # normally 1.28. Change to nc to prevent conflict,
# associated with zprobe the leveling strategy to use
leveling-strategy.three-point-leveling.enable true # a leveling strategy that probes three points to define a plane #and keeps the Z parallel to that plane
leveling-strategy.three-point-leveling.point1 10,80 # the first probe point (x,y) optional may be defined with M557
leveling-strategy.three-point-leveling.point2 150,80 # the second probe point (x,y)
leveling-strategy.three-point-leveling.point3 80,60 # the third probe point (x,y)
leveling-strategy.three-point-leveling.home_first true # home the XY axis before probing
leveling-strategy.three-point-leveling.tolerance 0.03 # the probe tolerance in mm, anything less that this will be ignored, default is 0.03mm
#leveling-strategy.three-point-leveling.probe_offsets 0,0,0 # the probe offsets from nozzle, must be x,y,z, default is no offset
leveling-strategy.three-point-leveling.save_plane true # set to true to allow the bed plane to be saved with M500 default is false
If ZMIN will trigger during bed levelling, you can’t use both limit switches, and bed levelling. You need to disable limit switches.
