No connection after firmware flash
Hi,
I just loaded new firmware onto my Re-arm and no the board isnt recognized anymore. When take the sd card out I can see that the firmware file changed to .cur, so that seems to work but the COM port stays silent.
Is there any hard/factory reset that doesnt lose the bootloader?
Cheers
Are you sure you flashed the firmware, and not the html file containing it ? What is your firmware.bin file size ?
well I flashed without the config file on the sd and that worked. ghost in the machine i guess.
