Non-cartesian 3D printer
Hello !
Very interresting work! Thanks for that!
I build a small CNC machine whose X and Y axis are replaced by linear arms pushing directly the spindle, in a “bipod” configuration. Stiffness and precision of the prototype are very impressive.
I am now working for a repstrap 3D printer declination, called “dipode” (open source project), which should be very simple, cheap, effective and outstandingly fast. I really think that this innovative non-cartesian machine could outperform any current repstrap, according to both cost, speed or precision, but I lack a good stand-alone electronics solution.
Today, these machines are drived (quite well) by emc2 / LinuxCNC running on an old laptop. Therefore, the step frequency limits the hardware speed.
As you probably know, emc2 uses a single c module to translate from cartesian space to machine’s linear drives (direct kinematics and inverse kinematics). You claim that Smoothie is tailored to handle non-cartesian architecture. I am not very comfortable with the software environment, so I need an example to learn how to cope with the relevant module.
Thanks for your help!
Hi !
Do you have any picture/schematic/rendering of your machine(s) ? I’d love to see that :slight_smile:
About your question, smoothie has completely abstracted arm solutions.
This means to add a new arm solution all you have to code is a now module for the arm solution.
A good example would be for example Logxen’s recent work on a delta robot arm solution : https://github.com/logxen/Smoothie/compare/arthurwolf:edge...logxen:rostock
It’s untested but it gives you a good idea of what is involved : basically you just have to provide a class, with functions that convert millimeters to steps, and smoothie takes care of the rest.
Cheers !
Thanks for your fast response. Good news!
The 3D printer proto is almost done. I promise a video as soon as possible.
What about SmoothieBoard availability?
Smoothieboard will be out in 20 days for the folks that are on the reservation list.
Hi Arthur
Just a follow on from this, I’m planning on building a DLP based 3D printer (z-axis only) but my design uses two motors. Am I right in thinking that I can do something similar to the above and code a new module that copies the Z axis motor?
Thanks
Hi !
You probably don’t even need to code anything. Just choose two stepper drivers on the Smoothieboard, connect their step/dir/enable pins together, and just drive one of them as Z, both will move :slight_smile:
If you don’t want to do any wiring, coding something is also possible, we have hooks that make this easy.
Cheers !
Thanks Arthur, just backed on Kickstarter :wink:
Thanks for backing !!
JPSB - you can do more simple than that : if you have a good quality driver with enough current output, you can also connect 2 stepper mtors to one driver !
DAniel
